wiced_network_up returns SET_BLOCK_ACK_WINDOW_FAIL
wiced_network_up returns SET_BLOCK_ACK_WINDOW_FAIL in the both the modes STA as well as SoftAP. I'm not able to figure out why it is happening.
As per my debugging, its setting something in the network controller and its not able to do that.
Is it a known issue and are there any fixes to this?
I don't hit this issue. Is it easy to reproduce this issue? which platform are you testing?
