Dear All:
My WICED device is always crash and reboot when web server is booted.
I check all system and no way to fix.
Can you give me a hint which cause a crash?
How can know crash is generated by hard fault, time out ....?
Is there any exception to printf a error message when crash?
hard fault, time out or any kind of reason why system is crash?
Sorry for the late reply. Did you download the latest SDK?
Arsh Buch
The webserver should work in any version of SDK.
I think you need to provide more details.
Which SDK-version and which network stack is used (NetX/NetX_Duo/LwIP)?
Can you reproduce the crash with snip code that running webserver?
Here's a thread where the users ran into similar issues with the webserver: Webserver Crashes (gre7g)
Which SDK version, application (BIG or SmartBridge, have you made changes?), and hardware (BRCM Eval Board, one from our Partners or custom) ?
My situation is like what you point.
SDK 3.1.2 Application(Gateway with Smart bridge) , I add camera and LCD function into code. HW: BCM43341 & STM32F429. I'm BCM Partners.
Even I remove all source code I add. reference is temp_control. System is still crash after a certain time.
The situation is the same. WIN7, chrome. javascript....
I have looked greg7 problem. But I can't get points how to solve it?
I use default one like demo.temp_control-STM32F429_BCM43340_Hercules download run
I guess it should threadx and netx_dual
If new SDK WICED 3.3.1 will help this one ?
