Wi-Fi Combo
Hi all,
     I want to use MFI and Bluetooth to contral a device together.I use apps_homekit examples.If only use mfi, it work.But when I add "wiced_bt_stack_init" after "wiced_init", it generate "WAC failure".  If I remove defined "USE_MFI=1", it will stop at function "wiced_homekit_start". So can I use ble with MFI? Or some docments and examples help?
MichaelF_56
Please submit all HomeKit SDK questions to the HomeKit private group.
If you need access to this group, please send a PM to the user gangi with your MFi license number and he will validate the license, then add you to the HomeKit group.
vik86
