Wi-Fi Combo
BaT_3785171
New Contributor II
I am porting a IAR source code written for STM32F411 to 43xxx_Wi-Fi project  (WICED studio 6.1 installed in my PC)
IAR code is written using HAL drivers.
and 43xxx_Wi-Fi project is based on standard peripheral library drivers.
What is the best way to port the code.
because i am  facing compilation errors.
For eg:
HAL  drivers  and standard peripheral library drivers have
a)same structure with different members.b)same variables with different data types.
RaktimR_11
Currently in WICED Studio, there is no straightforward way to do this, We are working on this feature addition internally which will be made available through our next generation Modus Toolbox IDE
RaktimR_11
