Wi-Fi Combo
user_2212361
New Contributor II
Hi
I want to download the firmware to evaluation board.
The guide describes the document download using the eclipse tool.
But I want to download in a manner other than eclipse tool.  via usb jtag interface..
The production can't use the eclipse tool.
Please inform me the way.
good luck.
Check -
WICED-AN800-R-Factory-Programming.pdf
MichaelF_56
This used to be included within the docs provided inside the SDK correct?
I can't seem to find it anymore.
MiTo_1583836
Contributor II
You can run make directly via command line. That's what Eclipse does in background. If you look at the logs when you execute the build and download to target you will see the command line that you need to execute. I found one in the documentation for example:
"C:\My Documents\Wiced-SDK\make.exe" snip.ping-BCM943362WCD4 download run
