Jan 03, 2016
09:28 PM
Jan 03, 2016
09:28 PM
Hi
I want to download the firmware to evaluation board.
The guide describes the document download using the eclipse tool.
But I want to download in a manner other than eclipse tool. via usb jtag interface..
The production can't use the eclipse tool.
Please inform me the way.
good luck.
Labels
Manufacturing and Test
10:09 PM
Jan 04, 2016
10:09 PM
11:38 PM
Jan 03, 2016
11:38 PM
Check -
WICED-AN800-R-Factory-Programming.pdf
Jan 04, 2016
07:17 AM
Jan 04, 2016
07:17 AM
This used to be included within the docs provided inside the SDK correct?
I can't seem to find it anymore.
Jan 04, 2016
07:08 AM
Jan 04, 2016
07:08 AM
Jan 04, 2016
08:01 AM
Jan 04, 2016
08:01 AM
You can run make directly via command line. That's what Eclipse does in background. If you look at the logs when you execute the build and download to target you will see the command line that you need to execute. I found one in the documentation for example:
"C:\My Documents\Wiced-SDK\make.exe" snip.ping-BCM943362WCD4 download run
10:09 PM
Jan 04, 2016
10:09 PM
