can i port a2dp source code from 20706_A2_Bluetooth to 43xx_wifi target?
akNa_4301246
Hi
i want to port a2dp source code(watch example) from 20706_A2 platform to 43xx_wifi platform.
is it possible to port the code from 20706_A2 to 43xx_wifi?
please provide any suggestions
thanks.
AnjanaM_61
10 questions asked 5 comments on KBA First comment on KBA
Controller CY4343W support A2DP .You need a Host and Host Stack (such as Android or BSA) for application of A2DP .
Currently Wiced studio SDK doesn't have the support for A2DP profile for BCM94343WWD2_EVB (which has STM controller as host) .
However as mentioned in the thread can i port a2dp profile from another target(wiced) to 43xx_wifi target(BCM94343WWD2_EVB?)  , you may refer the implementation used for our PSoC6+4343W (CY8CKIT_062) board which supports audio applications.
Anjana
AnjanaM_61
Anjana
