Wi-Fi Combo
I try to run bt_smartbridge Demo Application on my BCM943341WCD1 EVB. I use SDK 3.1.1.
I connect successfully to the board´s Web page through a shared Wifi Access Point.
Then a ask for BT devices scanning pushing "Rescan" button.
The "Scanning for Bluetooth Smart devices ..." message appears.
But then I get "No device found". I get the same result repeating several time these steps.
And however there are many devices Bluetooth devices around the EVB.
Do you have some idea about what could be wrong in my test?
Julien
GregG_16
Are you using BLE devices?
Can you try LightBlue App on your phone?
GregG_16
You are right, the devices I was using were not Bluetooth Low Energy Devices.
Now I emulate such devices with Iphone LightBlue App and I can see them from my BCM943341WCD1 EVB.
Julien
