Wi-Fi Combo
I am able to do the wifi testing on command prompt using wl tool (wl4343WA1.exe).
we have the source code of wl tool. which is located at 'libraries/test/wl_tool'
I want to do the wifi testing on command console  (test.console app) ?
Is it possible to do it ?
Would anyone help me, how to do it ?
I  am able to test the WIfI from  console app.
Steps to be followed,
Enable the "CONSOLE_ENABLE_WL ?= 1" in test/console.mk.
But it takes lot of memory.
so I disable all the other console application command and  only run the WL_COMMANDS.
It works.
It works.
AndrewY_86
Thank you for reporting back with the solution
