I just down load new Wiced 4.1, It is give me a below error.
make all MAKEFILE MAKECMDGOALS=all OTA2_SUPPORT is disabled Making config file for first time tools/makefiles/wiced_config.mk:244: platforms//.mk: No such file or directory tools/makefiles/wiced_config.mk:255: *** Unknown component: all. Stop. make: *** No rule to make target 'build/all/config.mk', needed by 'main_app'. Stop.
I cannot find proper tool chain for Complier and build
regards
terrance
SDK 3.x
Wifi+Bluetooth
which version of the SDK are you using (Linux, Windows, OSX)? Are you using the installers that are provided for each OS? What standard CY eval board do you have connected to the host that is running the SDK? Have you verified that the USB to Serial FTDI drivers are installed correctly on the host?
HI Madhu, I am using latest 4.1SDK windows 64bit Installer. I am not using standard SDK but bought from USI BM22 and BM30 which have Wi-Fi + BLE combo using Broadcom/Cypress chipset and WiFi only with Broadcom/Cypress chipset along with STM32F1,
I believed the project can compile without hardware, is that right?
terrance
You will need to contact USI or their regional distributor and obtain the correct platform files.
jone
terrancepeiris Which version SDK you used ? Is 4.1 ot 4.0.10 ?
We have to make sure which version you used ? Current release should be 4.0.10 on forum!
If you are used SDK 4.1.0 maybe only Cypress could help you !
Basic the cypress released SDK did not include any board market vendor's platforms !
So you could follow the Quick Start Guide to build the Cypress standard platform like BCM943362WCD4 or BCM943909WCD1xx without error !
Must patch the SDK with vendor's platform files to support vendor's it!
ASK your distiller to get specified platform files! (current only support to SDK 4.0.10)!
SDK 4.0.1 is the most recent version of the SDK supported here on the community. I assumed that this was the version you were referencing in your original post.
If you have a pre-release version of a newer SDK, then please contact the sales team that enabled you with the pre-release so that they can line up support.
Hi Guys, sorry to miss I am using a latest Wiced SDK 4.0.1
terrance
Hi jone terrancepeiris,
I hit a strange issue that on SDK-3.7.0-7:
Wifi network becomes unreachable once init bt stack on BCM43438 platform
(It was working on SDK-3.7.0 but does not work on SDK-3.7.0-3 and SDK-3.7.0-7)
You can test it by running demo.bt_internet_gateway.restful_smart_server
Can you help to test this on your BM22 device?
Just run restful_smart_server and ping the WICED device, you should be able to find ping OK after device got IP, but fails once BT init.
(To test it, you need to change YOUR_AP_SSID and YOUR_AP_PASSPHRASE in wifi_config_dct.h and also add BM22 to the VALID_PLATFORMS in the makefile)
Axel
I try Restful_smart_server on SDK 3.7.0-7 ! It work on ThreadX build! Both ping and retrieve data from via curl !
But FreeRTOS only ping success but fail on curl command
Jone
below is console dump for you reference
Starting WICED v3.7.0-7
Platform BCMUSI22.A0 initialised
Started ThreadX v5.6
Initialising NetX_Duo v5.7_sp2
Creating Packet pools
WWD SDIO interface initialised
WLAN MAC Address : 00:90:04:34:38:22
WLAN Firmware : wl0: Aug 8 2016 23:42:00 version 7.45.45.21 (r653573) FWID 01-7cea6c16
Joining : YOUR_AP_SSID
Successfully joined : YOUR_AP_SSID
Obtaining IPv4 address via DHCP
DHCP CLIENT hostname WICED IP
IPv4 network ready IP: 192.168.1.54
Setting IPv6 link-local address
IPv6 network ready IP: FE80:0000:0000:0000:0290:04FF:FE34:3822
00:00:11.023392 GKI_create_task func=0x8034499 id=1 name=BTU stack=0x0 stackSize=6144
00:00:11.031392 GKI_create_task func=0x8035d0d id=0 name=HCISU stack=0x0 stackSize=4096
Stack requests for local security keys
Bluetooth Internet Gateway initialised. BD address : 43:43:8A:10:BD:22
Store local keys in non-volatile memory
REST: LE scan completed.
Initialising NetX v5.5_sp1
00:00:04.003928 GKI_create_task func=0x80392f9 id=1 name=BTU stack=0x0 stackSize=6144
00:00:04.011928 GKI_create_task func=0x803ab6d id=0 name=HCISU stack=0x0 stackSize=4096
Started FreeRTOS v8.2.1
Initialising LwIP v1.4.0.rc1
Obtaining IP address via DHCP
Network ready IP: 192.168.1.54
00:00:03.040464 GKI_create_task func=0x80317c9 id=1 name=BTU stack=0x0 stackSize=6144
00:00:03.048464 GKI_create_task func=0x8033045 id=0 name=HCISU stack=0x0 stackSize=4096
00:00:04.016464 GKI_create_task func=0x80392f9 id=1 name=BTU stack=0x0 stackSize=6144
00:00:04.024464 GKI_create_task func=0x803ab6d id=0 name=HCISU stack=0x0 stackSize=4096
1-7cea6c16
00:00:03.004928 GKI_create_task func=0x80317c9 id=1 name=BTU stack=0x0 stackSize=6144
00:00:03.012928 GKI_create_task func=0x8033045 id=0 name=HCISU stack=0x0 stackSize=4096
Jone
Hi jone
Thanks for your feedback.
My test shows the ping failure problem only happens on BCMUSI22.A1 platform. (using 43438A1.bin)
Any chance to test it on BCMUSI22.A1 platfrom?
axel.lin There are only minor control pin defined change on BCMUSI22.A0 and A1 H/W revision !
The WiFi and MCU are the same! But any way !
The BM22.A1 have same result as A0
Log attached as below!
Jone
Platform BCMUSI22.A1 initialised
WLAN MAC Address : 6C:0B:84:C0:6A:F3
IPv4 network ready IP: 192.168.1.55
IPv6 network ready IP: FE80:0000:0000:0000:6E0B:84FF:FEC0:6AF3
00:00:11.004928 GKI_create_task func=0x8034495 id=1 name=BTU stack=0x0 stackSize=6144
00:00:11.012928 GKI_create_task func=0x8035d09 id=0 name=HCISU stack=0x0 stackSize=4096
Bluetooth Internet Gateway initialised. BD address : 6C:0B:84:C0:6A:F4
00:00:04.035464 GKI_create_task func=0x80392f1 id=1 name=BTU stack=0x0 stackSize=6144
00:00:04.043464 GKI_create_task func=0x803ab65 id=0 name=HCISU stack=0x0 stackSize=4096
00:00:04.020464 GKI_create_task func=0x80392f1 id=1 name=BTU stack=0x0 stackSize=6144
00:00:04.028464 GKI_create_task func=0x803ab65 id=0 name=HCISU stack=0x0 stackSize=4096
Network ready IP: 192.168.1.55
00:00:03.003928 GKI_create_task func=0x80317c1 id=1 name=BTU stack=0x0 stackSize=6144
00:00:03.011928 GKI_create_task func=0x803303d id=0 name=HCISU stack=0x0 stackSize=4096
00:00:03.016464 GKI_create_task func=0x80317c1 id=1 name=BTU stack=0x0 stackSize=6144
00:00:03.024464 GKI_create_task func=0x803303d id=0 name=HCISU stack=0x0 stackSize=4096
00:00:07.025928 GKI_create_task func=0x8034495 id=1 name=BTU stack=0x0 stackSize=6144
00:00:07.033928 GKI_create_task func=0x8035d09 id=0 name=HCISU stack=0x0 stackSize=4096
00:00:07.061464 GKI_create_task func=0x8034495 id=1 name=BTU stack=0x0 stackSize=6144
00:00:07.003928 GKI_create_task func=0x8035d09 id=0 name=HCISU stack=0x0 stackSize=4096
Could you tell me or guide me the correct documentation to setting the Make target on WICED 4.0.1, please?
I received the BM22 patch or platform files from USI but not sure where to place this file and how created make file to run the WICED
terry
Utar the patch under your SDK directory (43xxx_Wi-Fi in SDK 4.0.1).
It will add one platform call BCMUSI22 under 43xx_Wi-Fi/platforms directory and change necessary files!
Then you could build snip.scan example code by issue ./make snip.scan-BCMUSI22 to CMD box (or xtem for Linux) under the 43xx_Wi-Fi directory
If you want to build it under the IDE , please read the documents first!
Jone
