Wi-Fi Combo
I have BCM9WCDPLUS114 evk board. I use demo.bt_smartbridge application to verify smartbridge function.
I have three BLE modules, BCM920732_TAG, SensorTag from TI(http://www.ti.com/ww/en/wireless_connectivity/sensortag/index.shtml?INTC=SensorTag&HQS=sensortag) and LightBlue running on iPad. Below is scan and connect webpage:
[ATTACH=CONFIG]181[/ATTACH]
BCM9WCDPLUS114 can get three BLE devices by scan.
BUT, only LightBlue on iPad can connect with BCM9WCDPLUS114. BCM920732_TAG and SensorTag cant connect with BCM9WCDPLUS114, they are always "connecting".
Whats the reason? Paring authentication?
BLE is only supported from iPhone 4S onwards.
Which WICED-SDK version are you using? From the snapshot, it seems to me that youre using an older version of the SDK i.e. 2.3.1. Please try again with SDK 2.4.0. Thanks.
Hello gerdiman,
I use SDK 2.4.1 to run demo.bt_smartbridge application and try to connect a simulation device by LightBlue on iPhone4. But the Scan Results on webpage always shows:
No device found
Would you know why?
Hi gerdiman,
It's OK by using iPhone5 now.
Yes, my version is 2.3.1.
Its ok when run WICED 2.4.0.
