Wi-Fi Combo
Is this the WiFi board that works with HomeKit SDK? Broadcom BCM943362WCD4 WICED WiFi Module
Is there any Bluetooth version of the board that works with HomeKit SDK?
This board has no Apple Authentification copro, so you need to desactivate the flag 'USE_MFI'  : your configuration will be a non MFI Homekit accessory and it should work like this.
I believe this board should match your need BCM9WCDPLUS114
BR
Lionel
您的邮件我已经收到
