Wi-Fi Combo
Customer is using Inventek Module and need to confirm what will be the max available RAM memory could be used without affecting the TCP/IP application?
Gerardo
MichaelF_56
dickb
Maybe someone from the Inventek team can comment.
MichaelF_56
dickb
Gerardo,
for clarity does the positioning of this question suggest you are running your own WICED code on the Inventek module?
That is correct, my customer is using the ISM43362 but running the WICED on their application.
The have concerns about the max RAM that can be used by their own application and not affecting the performance of the TCP/IP stack.
thanks,
Gerry
