Need to port an application originally developed with WICED 3.5 platform to different MCU using latest MICO platform. The application interacts with cloud services (so uses tcp sockets, tls), http server to serve a small set of web pages, and typical hardware interfaces (SPI, GPIO, I2C). Trying to evaluate the port effort, can quantify the WICED calls in the original code to get a rough idea what must be translated into equivalent MICO Api's. That is somewhat informative, how ever there is not a direct one to one correspondence from WICED to MICO Api's , for example, http server demos apps look quite different between the two, so some code sections may require some rewrite.
Anybody have experience with a port like this? Suggest more accurate way to estimate the effort with regards to WICED/MICO differences?
WICED Studio
You can start by checking the HTTP_Server library implementation (43xxx_Wi-Fi/libraries/daemons/HTTP_server) of WICED vs MICO which can give you a very basic idea about the porting effort required.
