Wi-Fi Combo
I wanted to know whether wiced wifi sdk 3.3.1 NetX/NetX-duo tcp/ip stack supports keep alive functionality, because in source code I can see following:
wiced_result_t wiced_tcp_enable_keepalive( wiced_tcp_socket_t* socket, uint16_t interval, uint16_t probes, uint16_t time )
    UNUSED_PARAMETER( socket );
    UNUSED_PARAMETER( interval );
    UNUSED_PARAMETER( probes );
    UNUSED_PARAMETER( time );
     socket->socket.nx_tcp_socket_keepalive_enabled = WICED_TRUE;
    socket->socket.nx_tcp_socket_keepalive_retries = probes;
    socket->socket.nx_tcp_socket_keepalive_timeout = time;
     return WICED_TCPIP_UNSUPPORTED;
mwf_mmfaeseyhanjone
someone please reply
mwf_mmfaeseyhanjaeyoung
Kindly reply ASAP, my product release is based on this issue.
MichaelF_56
I have no idea on this one.  I will ask the applications team manager to assign someone from his team to research.
vik86 seyhan gangi
gangi
I am using Inventek systems module ISM43340-M4G-EVB.
mwf_mmfae
Thread you have given is related to wiced wifi sdk 2.31, however I am using sdk 3.31.
GregG_16
Whose module are you using?
We will look into this.
