WICED Studio Missing file
Merrick
Distributor - Weikeng(GC)
25 replies posted 10 questions asked 25 sign-ins
Hello
       There are missing files after wiced studio is installed. Please check the missing files and where to get them to complete the vulnerability.
17:54:07 **** Incremental Build of configuration Default for project 43xxx_Wi-Fi ****
"C:\\Users\\Merri\\Documents\\WICED-Studio-6.6\\43xxx_Wi-Fi\\make.exe" Default
MAKEFILE MAKECMDGOALS=Default OTA2_SUPPORT is disabled
Making config file for first time
tools/makefiles/wiced_config.mk:256: platforms//.mk: No such file or directory
tools/makefiles/wiced_config.mk:267: *** Unknown component: Default. Stop.
make: *** No rule to make target 'build/Default/config.mk', needed by 'main_app'. Stop.
17:54:07 Build Finished (took 346ms)
Charles_Lai
500 replies posted 250 solutions authored 250 sign-ins
You are facing compilation errors. Please check the configurations in your makefile and the build targets.
It's unlikely to be caused by missing files.
Aditi_B
500 replies posted 5 questions asked 250 replies posted
Which application are you building? Please provide the make target of your application.
Aditi
Merrick
Make target according to the development board process. Halfway through, show the problem.
tools/makefiles/wiced_config.mk:267: *** Unknown component: CY8CKIT_062. Stop.
make: *** No rule to make target 'build/snip.scan-CY8CKIT_062/config.mk', needed by 'main_app'. Stop.
The history is from CY8CKIT-062-WiFi-BT PSoC 6 WiFi-BT Pioneer Kit Guide document, page 27.
Charles_Lai
The supported products of WICED STUDIO 6.6 were shrunk down to the WICED WIFI/Combo families only. The PSoC family was removed.
Aditi_B
You can download MODUS TOOLBOX to get started on the kit that you've - CY8CKIT-062-WiFi-BT PSoC 6 WiFi-BT Pioneer Kit. The link for the same - https://www.cypress.com/products/modustoolbox
Aditi
AxLi_1746341
Level 7
Level 7
10 comments on KBA 5 comments on KBA First comment on KBA
