WICED Studio 6.4 installation failed on Mac Mojave ( 10.14.5 , 18F132 )
ImDu_4455396
- Any recommendation on what JRE  (or) JDK version to be used with Mac Mojave?.
- Not able to get SDK working with latest macOS available in the market.
- Please recommend the required settings.
WICED-Studio-6.4/.metadata/.log
!ENTRY org.eclipse.core.resources 4 2 2019-09-12 13:39:04.663
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
java.lang.NullPointerException
  at org.eclipse.ui.activities.WorkbenchActivityHelper.isFiltering(WorkbenchActivityHelper.java:236)
  at org.eclipse.ui.internal.ide.IDEWorkbenchActivityHelper$3.resourceChanged(IDEWorkbenchActivityHelper.java:158)
  at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
  at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
  at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
  at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
  at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:378)
  at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1498)
  at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:45)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Murali_R
250 sign-ins 250 replies posted 100 solutions authored
Hi
Could you try and follow the steps mentioned in this blog post  WICED-Studio 6.4.0 Installer (OSX) and let us know if the issue persists?
The java version needs to be below 9.x
Murali_R
Hi
