We are using the WICED-Studio-6.0.1 on BCM94341WCD1_2 and write a simple APP to try to connect the ble device.
Now we scan the ble device and try to call the wiced_bt_gatt_le_connect() to connect the ble deivce, but the gatt_event_callback() will always return connection fail and the reason code is 0x100 (L2CAP_CONN_CANCEL).
We can't find more info for this reason code.
Have any suggestion for it?
I tried your application but with WICED 6.0 build and didn't find any issue. Attached is the log I see at my end.
Have you tried with a different peripheral?
I attache our test app.
We copy from the apps\demo\bt_internet_gateway\bt_http_proxy_service\hps_client_keypad, and make this simple app.
We just scan a fixed bd_addr and try to connect this device, and the result always return fail.
But when I print a lot dummy string, the connection become success.
Thanks for any suggestion.
