Wi-Fi Combo
I just installed WICED SDK 3.5.2 with IDE under Windows. I cannot find in "Make Target" anything related to BCM4390x boards although under platforms folder I can see few BCM4390x enlisted.
Is WICED-SDK 3.5.2 with IDE supporting BCM4390x or developers are supposed to build without IDE?
You can add/modify Make Target.
Please right click on Make Target and then select New or Edit from pull-down menu.
Platform name need to be match with directory name under <WICED-SDK>/platforms/.
Please refer <WICED-SDK>/Makefile for detail.
