- Email to a Friend
In WICED 5.2, in the file 43xxx_Wi-Fi/WICED/platform/MCU/wiced_dct_internal_common.c,
shouldn't lines 616 - 621 be inside the previous #if - #endif block?
- wiced studio 5.2
- Email to a Friend
Sorry for not giving the entire explanation earlier.
CRC is included in header(platform_dct_header_t) in SDK version prior to Wiced 3.6.3. After SDK 3.7.0, CRC is moved to version (platform_dct_version_t) section. So all the recent versions have CRC in version. Hence the macro DCT_BOOTLOADER_CRC_IS_IN_HEADER is not defined in the current version. Hence the variable curr_dct will always be declared. Consequently the other part of the code you are pointing will also work.
One more point, if we compare the function wiced_dct_finish_new_dct() in wiced_dct_internal_common.c and wiced_dct_external_common.c file, it appears that curr_dct should not be declared in the #if - #endif block. (I will discuss this internally and update you if we incorporate this change)
- Email to a Friend
I hope you are pointing to this piece of code:
if (platform_write_flash_chunk(curr_dct + OFFSETOF(platform_dct_data_t, dct_version) + OFFSETOF(platform_dct_version_t, initial_write), &zero_byte, sizeof( zero_byte )) != 0)
return WICED_ERROR;
It is not a bug.
- Email to a Friend
Hello riya and thank you for your time!
My question is that in that particular function (wiced_dct_finish_new_dct) the variable curr_dct is only defined when the macro DCT_BOOTLOADER_CRC_IS_IN_HEADER is not defined.
Therefore, the code block you mentioned should be in the previous #if !defined(DCT_BOOTLOADER_CRC_IS_IN_HEADER) block (starts at line 609), since it uses that variable.
- Email to a Friend
- Email to a Friend
Hello Riya and thank you,
This is very relevant to my situation, since we are upgrading our firmware from WICED version 3.5.2 (UPDATE_FROM_SDK=3_5_2) to the latest one!
- Email to a Friend
I see that this is still an issue with version 6.1 of the SDK
