Hi!
I'm running a TCP server on Wiced AP interface and there are some issues with that when wanting to have multiple of sockets at the same time. I'm using ThreadX NetX-Duo.
Wiced has a wrapper API for TCP socket listen that defaults to the STA interface:
wiced_result_t wiced_tcp_listen( wiced_tcp_socket_t* socket, uint16_t port );
This has to be modified if you want to use the AP interface. Please add a new API or add interface parameter to the existing one.
Please consider adding:
wiced_result_t wiced_tcp_listen_ap( wiced_tcp_socket_t* socket, uint16_t port );
tcp_listen_callback_t listen_callback = NULL;
struct NX_TCP_LISTEN_STRUCT* listen_ptr;
WICED_LINK_CHECK( socket->socket.nx_tcp_socket_ip_ptr );
/* Check if there is already another socket listening on the port */
listen_ptr = IP_HANDLE(WICED_AP_INTERFACE).nx_ip_tcp_active_listen_requests;
if ( listen_ptr != NULL )
/* Search the active listen requests for this port. */
do
/* Determine if there is another listen request for the same port. */
if ( listen_ptr->nx_tcp_listen_port == port )
/* Do a re-listen instead of a listen */
if ( nx_tcp_server_socket_relisten( socket->socket.nx_tcp_socket_ip_ptr, port, &socket->socket ) == NX_SUCCESS )
return WICED_SUCCESS;
else
return WICED_ERROR;
listen_ptr = listen_ptr->nx_tcp_listen_next;
} while ( listen_ptr != IP_HANDLE(WICED_AP_INTERFACE).nx_ip_tcp_active_listen_requests);
/* Check if this socket has an asynchronous connect callback */
if (socket->callbacks[WICED_TCP_CONNECT_CALLBACK_INDEX] != NULL)
listen_callback = internal_tcp_listen_callback;
if (socket->socket.nx_tcp_socket_state != NX_TCP_CLOSED)
nx_tcp_server_socket_unaccept( &socket->socket );
if ( nx_tcp_server_socket_relisten( socket->socket.nx_tcp_socket_ip_ptr, socket->socket.nx_tcp_socket_port, &socket->socket ) == NX_SUCCESS )
else
return WICED_ERROR;
else
if ( nx_tcp_server_socket_listen( socket->socket.nx_tcp_socket_ip_ptr, port, &socket->socket, WICED_DEFAULT_TCP_LISTEN_QUEUE_SIZE, listen_callback ) == NX_SUCCESS )
else
return WICED_ERROR;
TCPIP
You're right, thanks for reporting this.
A separate API shouldn't be necessary though because the socket is created using the function wiced_tcp_create_socket( wiced_tcp_socket_t* socket, wiced_interface_t interface ) which is created for a particular interface. The right approach is to grab the interface info from the socket object instead of having it hardcoded as STA. We'll fix this up in the next release.
