Stripped Elf file name change broke our Factory Install script
We recently upgraded to WICED 3.5.2, but a file name change in the stripped elf that is generated by the build broke our factory install script.In the past each subfolder of WICED-SDK/apps was separated by "_" now for at least one stripped elf, they are separated by "."
