I am working on Inventek ISM43341 eval kit based on BCM43341.
I need to set tx power of BLE in peripheral mode.
I can see api to read tx power wiced_bt_dev_read_tx_power(),
But, unable to find api to write/set tx power.
Is this api  available or already tx power is set in BCM43341 firmware only ? mwf_mmfae
MichaelF_56
We checked with the developers and determined that we default to BT Class 1.5 on Tx, which equates to 10dBm.
Unfortunately, we do not provide an API to change the default output power.
jguillor arvinds
MichaelF_56
jguillor arvinds
