IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
Wi-Fi Combo
AxLi_1746341
Honored Contributor
In WICED/platform/MCU/STM32F4xx/platform_init.c:
The code in platform_init_mcu_infrastructure() is very strange.
platform_rtc_init() is guarded by #ifndef WICED_DISABLE_MCU_POWERSAVE,
which means RTC is not initialized if define WICED_DISABLE_MCU_POWERSAVE.
i.e Define WICED_ENABLE_MCU_RTC does not work if WICED_DISABLE_MCU_POWERSAVE is set.
This looks like a bug.
PriyaM_16
I agree to your comments.
RTC initialization should not be guarded by WICED_DISABLE_MCU_POWERSAVE. Enabling powersave should not stop initialization of RTC.
I will escalate the issue internally. Thank you for bringing this to our notice.
AxLi_1746341
Honored Contributor
FYI, this is still not fix in your latest sdk.
ErSt_4460741
New Contributor II
As AxLi_1746341 states, it is still not updated in your latest SDK.
I performed this issue also and can confirm this is the correct solution
AxLi_1746341
Honored Contributor
But the latest sdk does not fix it, why? Is there other issue to block the fix?
