Wi-Fi Combo
Dear,
        I am testing the OTA Update using the program of snip.ota_fr in WICED SDK v2.4.1.
         The comments in this ota_fr.c told me that the first step is running this command as follow:
          snip.ota_fr-BCM943362WCD4  OTA=waf.ota_upgrade  SFLASH=app-dct-ota-download
        The platform  I used is BCM9WCDUSI09, so I changed the command as:
         snip.ota_fr-BCM9WCDUSI09  OTA=waf.ota_upgrade  SFLASH=app-dct-ota-download
         But it failed. Is  the RAM too small?
         The Log is in the attachment.
          Could anyone help me to find the problem? Thanks.
          BTW, the SPI Flash in my board is 4MByte.
I do not modify the file,you can fine sflash_get_size() func,and in the func you can know,it only supports  SFLASH_SUPPORT_MACRONIX_PARTS and SFLASH_SUPPORT_SST_PARTS menufacture`s device,and the flash id  must be SFLASH_ID_MX25L8006E or SFLASH_ID_SST25VF080B.Acturally i do not know bcm do like this.if your flash does not match,you will get the size of flash 0 size.
The platform I used is  BCM943362WCD4 ,but i got the same error as you.like this:
16384 bytes written at address 0x2000001c
downloaded 16384 bytes in 0.234375s (68.267 KiB/s)
****************** Result: Size too big for chip
writing 16384 bytes at 65536
loadimage address 536870940 foffset 65536 16384
downloaded 16384 bytes in 0.218750s (73.143 KiB/s)
writing 16384 bytes at 81920
But there is another error message before that:
Building the OTA-Upgrade App
Skipping building bootloader due to commandline spec
Making .gdbinit
Could not find start/end addresses of Flash
waf_ota_upgrade-BCM943362WCD4-
Do you mean that it  is likely to be a bug of the SDK V2.4.1 and that I can't fix it by myself?
I am not sure,did you connect the FAE of BCM?
No, I haven't yet. I will try it.
Thank you all the same.
I have resolved the question...,It is because the flash ID is not match.
Do you only modify the SFLASH_ID_XXXXXX in spi_flash_internal.h(SDK\Wiced\Platform\common\drivers\spi_flash\ )?
Thanks a lot!
When I tried with BCM943362WCD4_EVB, it succeeded.
The console log is attached.
did you modify anything else?
I don't think so.
In your Log, I found this:
waf_sflash_write-NoOS-NoNS-BCM943362WCD4-
                                  |        |  Static |
              Module              |  Flash  |  RAM  |
App                              |      0 |  22071 |
Host MCU-family library          |      0 |    8211 |
Interrupt Vectors                |      0 |    436 |
libc                              |      0 |  25126 |
Platform                          |      0 |    676 |
SPI Flash Library                |      0 |    1236 |
Startup Stack & Link Script fill  |      0 |    5536 |
WWD                              |      0 |    196 |
TOTAL (bytes)                    |      0 |  63488 |
In my Log:
waf_sflash_write-NoOS-NoNS-BCM9WCDUSI09-
                                  |        |  Static |
App                              |      0 |  22071 |
Host MCU-family library          |      0 |    8207 |
libc                              |      0 |  25126 |
Platform                         |      0 |    760 |
Startup Stack & Link Script fill  |      0 |    5552 |
WWD                              |      0 |    196 |
TOTAL (bytes)                    |      0 |  63584 |
Is there any other critical difference?
I'm not sure.
Actually I removed some printf like "Platform xxxx initialised".
But it doesn't affect this I think.
