Wi-Fi Combo
Hi Guys,
Is it possible to overwrite factory reset application image (FR APP) on external flash (after it has been programmed at a time of manufacturing)? Does WICED Application framework support it?
Oleg
In theory yes, The FR_APP is just another application that can be updated through the mutli application API. However this doesn't sound like a good idea because the FR_APP is basically your backup application in case your normal running application got corrupted. if the FR_APP had any errors in it due to failing update, then you will end up with a dead board.
Bassem
Bassem
