I am trying to run the snip scan as per the Quick Start Guide in the debugger.
The debugger comes up as expected with the first line of code - exactly as shown in the QSG. The only exception is that in the Console messages I get
stepi ignored. GDB will now fetch the register state from the target.
When I try to get the program to run (F8 - takes 2 continues to run) (having already set a breakpoint in the scan.c code) it stops at the end of for the vPortYieldFromISR routing in port.c. When i try to get the program to repeatedly stops here never advancing to the breakpoint in scan.c
Without a breakpoint set the code executes without stopping. I have tried other code snips with the same results
I think the configuration of the debugger is correct but the directions listed in the QSG seem to be for an earlier version and their are some minor differences as I installed the software
Debug
- advancing
- breakpoint
- code
- configuration
- console
- continues
- correct
- debugger
- differences
- directions
- earlier
- exception
- executes
- expected
- fetch
- guide
- installed
- line
- listed
- messages
- minor
- openocd
- port.c
- program
- quick
- register
- repeatedly
- results
- routing
- scan
- scan.c
- shown
- snip
- snips
- software
- start
- state
- stepi
- stopping
- stops
- takes
- target
- version
- vportyieldfromisr
Discussion is being locked. If you have any follow-up, please start a new discussion.
