for building OpenOCD, i was running './build_all.sh' script using MINGW, Msys, Git. tools in 32-bit Windows System,
but below build error message is printed.
maybe, 'just_libusb.sh' script is built, this error message is printed.
../../libusb-1.0.19/libusb/os/windows_usb.c: In function 'get_windows_version':
../../libusb-1.0.19/libusb/os/windows_usb.c:850:4: error: implicit declaration o
f function 'VerSetConditionMask' [-Werror=implicit-function-declaration]
major_equal = VerSetConditionMask(0, VER_MAJORVERSION, VER_EQUAL);
../../libusb-1.0.19/libusb/os/windows_usb.c:850:41: error: 'VER_MAJORVERSION' un
declared (first use in this function)
../../libusb-1.0.19/libusb/os/windows_usb.c:850:41: note: each undeclared identi
fier is reported only once for each function it appears in
../../libusb-1.0.19/libusb/os/windows_usb.c:850:59: error: 'VER_EQUAL' undeclare
../../libusb-1.0.19/libusb/os/windows_usb.c:860:42: error: 'VER_MINORVERSION' un
minor_equal = VerSetConditionMask(0, VER_MINORVERSION, VER_EQUAL);
cc1.exe: some warnings being treated as errors
make[1]: *** [os/libusb_1_0_la-windows_usb.lo] Error 1
make[1]: Leaving directory `/home/Ssery/source/libusb-build/libusb'
make: *** [install-recursive] Error 1
how can I resolve this build error?
Thank you.
add export EXTRA_CFLAGS=-DWINVER=0x500,
before build libusb
Thank you, jone.
when export EXTRA_CFLAGS=-DWINVER=0x500 is added at 111 Line in just_libusb.sh,
Building this script using MinGW was successful !!
And also, the installation of some libraries and packages in MinGW\bin are required depending on the OS.
+ The related issue was referenced in the website below.
