Wi-Fi Combo
RAS_3434296
New Contributor
Hi team I am using murata Type1LD Wifi module - Wiced studio 6.2
I plan to use wifi module internal flash for store around 2KB data of data .
Any one have sample code for internal flash read/write  .
Please help.
Thanks and Regards
Ravi S
RaktimR_11
You can use the dct section in internal flash.
There is already a dct_read_write application present inside SDK.43xxx_Wi-Fi/apps/snip/dct_read_write
If you want to know more about dct, you can look at 43xxx_Wi-Fi/doc/WICED-DCT.pdf
RaktimR_11
RAS_3434296
New Contributor
Hi RaktimR ,
Thanks for your quick response ...
I will check and update .
Thanks and Regards
Ravi S
