Multiple application execution on CYW943907AEVAL1F - Free RTOS - LwIP
veb_4093841
Hi ,
In our project we need to load the production test application and main application at once.First production application has to start  and perform the tests, after the tests it should set switch to main application. We have common DCT for both applications and device doesn't use any of the sleep modes.
As per the Multiple application execution on CYW943907AEVAL1F  article it is possible to use multiple applications with ThreadX. But our project uses Free RTOS and LwIP.
Is it possible to achieve multiple application with Free RTOS  ??  please share the details for the same.
PriyaM_16
250 replies posted 100 replies posted 50 replies posted
The application does not work for FreeRTOS-LwIP combination by default.
PriyaM_16
