I've been unable to modify the wifi config section of the DCT.
The modification appears to be successful. The failure occurs when I make the wiced_network_up() call following the DCT modification. The board fails to connect three times and then returns the 1024 error code.
I'm using the dct_read_write snip as a starting point.
Below is a stripped down version of the dct_read_write snip that modifies the network name & password before connecting to the network.
static const char* network_name = "___";
static const char* network_password = "___";
void application_start( )
platform_dct_wifi_config_t* dct_wifi_config = NULL;
wiced_init( );
print_wifi_config_dct();
wiced_dct_read_lock( (void**) &dct_wifi_config, WICED_TRUE, DCT_WIFI_CONFIG_SECTION, 0, sizeof( *dct_wifi_config ) );
strcpy( dct_wifi_config->stored_ap_list[0].details.SSID.value, network_name );
strcpy( dct_wifi_config->stored_ap_list[0].security_key, network_password );
wiced_dct_write( (const void*) dct_wifi_config, DCT_WIFI_CONFIG_SECTION, 0, sizeof(platform_dct_wifi_config_t) );
wiced_dct_read_unlock( dct_wifi_config, WICED_TRUE );
wiced_network_up( WICED_STA_INTERFACE, WICED_USE_EXTERNAL_DHCP_SERVER, NULL );
WPRINT_APP_INFO( ( "DONE\r\n" ) );
I'm not sure if I'm supposed to use the strcpy() function to modify the dct_wifi_config->stored_ap_list[0].details.SSID.value & dct_wifi_config->stored_ap_list[0].security_key variables. I saw this line ( strcpy( app_dct->string_var, modified_string_var ); ) in the dct_read_write snip, and was hoping they all work the same way.
Thanks for any thoughts.
- Bradley
Wifi+Bluetooth
I replaced the strcpy() functions with the following:
dct_wifi_config->stored_ap_list[0].details.SSID.length = strlen( network_name );
strncpy((char*)dct_wifi_config->stored_ap_list[0].details.SSID.value, network_name, strlen( network_name ));
memcpy((char*)dct_wifi_config->stored_ap_list[0].security_key, network_password, strlen( network_password ));
dct_wifi_config->stored_ap_list[0].security_key_length = strlen( network_password );
I should credit this post: Re: Is there a way to dynamically add AP's to the DCT?
Additionally, I found the wiced_network_set_hostname( const char* name ) call in the wiced_network_common.c file.
That call doesn't seem to do anything. Maybe I'm using it wrong.
