On Wiced 3.1.2 SDK after STA mode the board will connect to MQTT broker. But after some times the connection to MQTT broker breaks down intermittently on open network.
On local network it will work fine without breaking the connection.
Please provide inputs on this issue.
I am using platform BCM943362WCD4 and BCM9WCD5EVAL1.
Hi Adhiya,
Have you tried with the latest sdk?
The latest sdk can be downloaded from here.
Kindly let us know if you have any more questions.
AB
You need to mention the network stack your are using, NetX/NetX_Duo/LwIP?
Which MQTT broker are you using for test.
How long for the connection to get lost. (Is it hard or easy to reproduce?)
I am using using LwIP network stack, FreeRTOS.
MQTT broker version 1.4.1. After 5 to 10 mins it will break the connection. It is easy to reproduce.
Hi Adhiya,
AB
