Wi-Fi Combo
NaFi_2915566
New Contributor II
Based on OpenOCD -WICED and CYW943907AEVAL1F JTAG Header , I need to install libusb drivers to use Segger JLink.  Thsis may nto be possible with all the PCs we are using.
Can someone suggest a different JTAG adapter that is supported by Wiced Studio without adding libusb drivers?
The target device is CYW43907 1GC.
thank you
WinstonF_61
What version of WICED are you using. If its WICED 6.2 then you do not need to install libusb drivers.
Downloading through Jlink Segger in WICED SDK 6.2 and future releases. This blog covers the details for it.
Winston
WinstonF_61
Winston
NaFi_2915566
New Contributor II
you also need to follow the instructions in the correct response to Re: Flash CYW43907 with Segger standard tools (J-Flash, J-Flash Lite, Command Line) .
