Based on OpenOCD -WICED and CYW943907AEVAL1F JTAG Header , I need to install libusb drivers to use Segger JLink. Thsis may nto be possible with all the PCs we are using.
Can someone suggest a different JTAG adapter that is supported by Wiced Studio without adding libusb drivers?
The target device is CYW43907 1GC.
thank you
WICED Studio
Wireless MCU
- jtag
What version of WICED are you using. If its WICED 6.2 then you do not need to install libusb drivers.
Downloading through Jlink Segger in WICED SDK 6.2 and future releases. This blog covers the details for it.
Winston
Winston
you also need to follow the instructions in the correct response to Re: Flash CYW43907 with Segger standard tools (J-Flash, J-Flash Lite, Command Line) .
