Wi-Fi Combo
basically my application is multi threaded and  i'm creating multiple communication points.
but at a time i can create only one
there some api list which i'm using
wiced_result_t wiced_tcp_enable_tls( wiced_tcp_socket_t* socket, void* context );
wiced_result_t wiced_tcp_create_socket( wiced_tcp_socket_t* socket, wiced_interface_t interface );
wiced_result_t wiced_tcp_connect( wiced_tcp_socket_t* socket, const wiced_ip_address_t* address, uint16_t port, uint32_t timeout_ms );
wiced_result_t wiced_tcp_disconnect( wiced_tcp_socket_t* socket );
wiced_result_t wiced_tcp_delete_socket( wiced_tcp_socket_t* socket ); ....
CaWo_1798781
New Contributor II
It's possible you're running out of heap; we've had this issue before as well, not being able to establish more than one TLS connection.
