Wi-Fi Combo
TiWr_3840991
New Contributor
I have purchased an Inventek ISM43362 evaluation module that programs over the USB. I would like to learn how to program this device with my ST-Link/v2 in Wiced Studio.
I am not familiar with setting up make files or setting up targets in eclipse as some of the suggestions i found through google.
Any help would be appreciated. No I really do not want to purchase another Jtag device.
WinstonF_61
twrightbrandt_3840991
You could have a look at this help article Adding ST-Link support in WICED this might help.
I should warn you that is method has by no means gone through systematic validation that most of our other software and patches go through. We got it to work on our setup, hence sharing the same.
Winston
TiWr_3840991
New Contributor
Thanks mifo for the connections. I have already been in touch with Inventek and they were very helpful. This issue that I am working now is not an Inventek issue. It is a matter of setting up a JTAG programmer in Wiced Studio.
WinstonF_61
Winston
TiWr_3840991
New Contributor
Winston,
Thank you for the link. I will give this a look and see where it leads me.
RaktimR_11
You can also try adding
HOST_OPENOCD := scripts/target/stm32f4x_stlink
JTAG         := scripts/interface/stlink-v2
in your platform.mk file and check if that helps.
VoAn_2766281
New Contributor
I am also trying to connect WICED 5.2 to and STM32F4 board using ST-Link but cannot get it to work. What WICED version were used in the original post (Adding ST-Link support in WICED ) ?
