Dear Sirs,
I want to wirte 512KB data to the Flash of BCM94343W_AVN kit, then read these data by the application. I found many new starters(like me) have this question, but there is no a clear and complete anser or docment for this in our WICED docs. Anyone could kindly help this? Thank you.
Do you mean internal flash or external flash? If you want your data to be persistent across power cycle, it's better to make use of dct instead of sflash where you have a chance of ending up corrupting the sflash. For reference, you can look into snip.dct_read_write app. You can also look into this CYW43907 with External SFLASH in WICED post for some relevant inputs.
