Wi-Fi Combo
[WICED-SDK-2.2.1]
Im trying to do a UDP broadcast on port 56700,  do I send it on an IP address of 255.255.255.255
should my wiced_udp_send call look like this?
const wiced_ip_address_t INITIALISER_IPV4_ADDRESS( target_ip_addr, 0xFFFFFFFF ); .
wiced_udp_send(&udp_socket, &target_ip_addr, 56700, packet)
Is there anything special I need to enable?
The snip.udp_transmit app provides an example of how to send a
UDP packet to a broadcast address on the subnet 192.168.0.x
