Wi-Fi Combo
saroc_4017081
New Contributor
How to implement Location tracking based on time of arrival (TOA) using WICED ?
MuraliR_36
WICED doesn't support Location tracking based on Time of Arrival.
Please let us know what device you are using.
MuraliR_36
saroc_4017081
New Contributor
Thanks for your answer.
Murata Module : LBEE5HY1MW
Cypress IC: CYW43455
Saulo Rodrigues
MuraliR_36
Hi Saulo,
Are you trying to implement it with Bluetooth or Wi-Fi?
saroc_4017081
New Contributor
Current project use BLE RSSI, to estimate the distance from device to cellphone, however BLE signal could be effect by any change in the ambient. The idea to use WiFi is that in theory is robustness than BLE.
MuraliR_36
We understand the idea.
But as indicated before WICED doesn't support Location tracking based on Time of Arrival.
