We have made JTAG JIG. It was designed such as WICED-SDK-2.4.1\WICED-SDK\Doc\Schematics\BCM9WCD1EVAL1\BCM9WCD1EVAL1_P405
But USB Serial Port Devices was appeared in Device Manager in Win7.
I think, When WICED USB JTAGE Deivces is appeared in Device Manger, Jtag will be doing well
Let me know how to change from USB serial Port device(FTDI2232) to WICED USB JTAG device
SPI
- bcm9wcd1eval1
- ftdi
- jtag
- sdk 2.4.1
- serial port
- serial port devices
- usb
- usb jtag
- usb jtag device
- usb serial port device
- win7
Hi Hyunseok,
FTDI chip needs to be programmed to work in your case.
Please take a look at this posting Re: WICED USB JTAG programming not working.
For target boards, you may not need to add FTDI chip to program the Wiced device. It is possible to add a JTAG port and program it via external JTAG programmer.
Hope it helps.
Hi seyhan,
I can't see the attached file so i didn't try to program FTDI chip.
I've sent a message to jasonrc and I've been wating the reply for two weeks.
Maybe, if you know how to reprograming, could you explain it to me?
Hyunseok lee
