HyCh_2920631
I am wondering what to do if I want to download the image(I have already built) on the board without recompiling it again.
./make 'app'-'platform' download run command is 'build + download + run' right?
I can't find a command for only download/flash (without build)
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
Hi  hyeseung:
I just find a way to just download the image you compiled. below are the steps:
I am using the 20719-B1_Bluetooth evb to do a test .
1.  demo.hello_sensor-CYW9207x9WCDEVAL UART=COM6 download
  keep this command, and didn't skip the compile process.
2.  find the makefile in ..\WICED-Studio-6.0\20719-B1_Bluetooth\platforms\CYW9207x9WCDEVAL
    and find this makefile,  CYW9207x9WCDEVAL.mk
3.  change the download directory name in the download_using_chipload:
it always to choose the  images from \WICED-Studio-6.0\20719-B1_Bluetooth\build
you need to change the key word "build"  into another directory ,  and copy all the images you think that is stable for a backup.
in this case i just change it into "123" directory .
you may have a try , but actually this doesn't skip the build and link process of the current project.
$(QUIET)$(ECHO_BLANK_LINE)
$(QUIET)$(eval UART:=$(shell $(CAT) < com_port.txt))
$(QUIET)$(if $(UART), \
        $(ECHO) Downloading application... && $(call CONV_SLASHES,$(CHIPLOAD_FULL_NAME)) -BLUETOOLMODE -PORT $(UART) -BAUDRATE $(PLATFORM_BAUDRATE) $(CHIPLOAD_REBAUD) $(CHIPLOAD_NO_READ_VERIFY) $(CHIPLOAD_CRC_VERIFY) -MINIDRIVER $(SOURCE_ROOT)platforms/$(PLATFORM_FULL)/$(PLATFORM_MINIDRIVER) -BTP $(SOURCE_ROOT)platforms/$(PLATFORM_FULL)/$(PLATFORM_BOOTP) -CONFIG 123/$(OUTPUT_NAME)/$(OUTPUT_NAME).hex -LOGTO 123/$(OUTPUT_NAME)/logto.log > 123/$(OUTPUT_NAME)/download.log 2>&1 \
&& $(ECHO) Download complete && $(ECHO_BLANK_LINE) && $(ECHO) $(QUOTES_FOR_ECHO)Application running$(QUOTES_FOR_ECHO) \
|| ($(ECHO) $(QUOTES_FOR_ECHO)****Download failed ****$(QUOTES_FOR_ECHO) && $(call CONV_SLASHES,$(PERL)) $(AFT) 4 123/$(OUTPUT_NAME)/download.log && \
$(ECHO) Download failed. This WICED platform of the SDK only supports download to 207x9B1 devices.))
Zhengbao_Zhang
Hi  hyeseung:
