Wi-Fi Combo
TLS exemple work fine but the certificate is hardcoded.
Is it possible to download the certificate during the handshake ?
Ludo
VinayakS_26
Hi Ludo,
You could also write an application that hosts a webpage where you could upload the certificate rather than using the one present in DCT.
VinayakS_26
Hi Ludo,
Could you clarify on what you meant by "downloading the certificate". The ca certificate and the private key are stored in the DCT. You could generate your own certificate and private key pair and add the path to it in the application Makefile.  Is it that you want to fetch and display(in UART terminal)the negotiated server certificate during handshake while your WICED device acts as a client?
VinayakS_26
Hi Ludo,
