Failed to create the JVM on macOS with WICED Studio 6.6
Calvin
First solution authored First reply posted First question asked
Hi there,
I just installed the latest version WICED Studio for macOS 11.4.
My Java version is:
java version "1.8.0_301"
Java(TM) SE Runtime Environment (build 1.8.0_301-b09)
Java HotSpot(TM) 64-Bit Server VM (build 25.301-b09, mixed mode)
But I always get this alert. Any suggestion?
Thanks, @Murali_R. It works like a charm.
Also, a better guide for specifying JVM for Eclipse on macOS: https://wiki.eclipse.org/Eclipse.ini#-vm_value:_macOS_Example
Also update $JAVA_HOME: https://developer.apple.com/forums/thread/666681
Murali_R
250 sign-ins 250 replies posted 100 solutions authored
Looks like this is an issue with java running on macos and not WICED. check these  out. they might help you. https://developer.apple.com/forums/thread/667957 https://www.pushing-pixels.org/2020/06/19/fixing-the-failed-to-create-the-java-virtual-machine-error...
