Wi-Fi Combo
DS_Lin
Contributor II
Hi Sir,
see comments below..How do you start  OpenOCD -WICED&CYW954907AEVAL1F....Jlink Segger?
OpenOCD -WICED
Downloading through Jlink Segger in WICED SDK 6.2 and future releases
Br,
DS
Zhengbao_Zhang
Hello:
I think the blog address you posted above should already show the process clearly .
I think you need to prepare 43907 evb board, then study the Jlink connection for the first step.
Zhengbao_Zhang
Hello:
DS_Lin
Contributor II
Hi ZhengbaoZ_96,
I want to use Jlink Segger, then run on the CYW954907 platform, and then connect to the OpenOCD -WICED.
Zhengbao_Zhang
Hello:
From the link we should already verify the Jlink Segger  debugging.
DS_Lin
Contributor II
Hi ZhengbaoZ_96,
So 54907 can also be done?
