Do I need to specify the RTOS, Network Stack, etc in the build string?
[WICED-SDK-2.2.1]
Some example apps have a build string like this:
snip.ping-BCM943362WCD4 download run
while others have more options:
snip.ping-ThreadX-NetX_Duo-BCM943362WCD4-SDIO download run
Where are the defaults defined for my platform?
Do I need to specify all options?
Default options for a particular platform are defined in the platform Makefile here:
<WICED-SDK>/Wiced/Platform/<YOUR_PLATFORM_NAME>/<YOUR_PLATFORM_NAME>.mk
These defaults may be overridden in the build string per your second example.
