I'm using the BCM943362WCD4_EVB with WICED-Studio(WICED-SDK Version: Wiced_006.000.001.0005).
I can't debugging when I received signal SIGTRAP.
Could you tell me how to fix?
1. Make snip.scan-BCM943362WCD4-debug download
2. Run 43xxx_Wi-Fi_Debug_Windows
on Console:
[New Thread -268280318]
Program received signal SIGTRAP, Trace/breakpoint trap.
[Switching to Thread -268280318]
0x0800c63a in _start () at WICED/platform/MCU/STM32F2xx/../../ARM_CM3/crt0_GCC.c:81
81 __asm__( " ldr r1, =link_stack_end\n"
WICED Studio
Hi T-mat:
Did you finish the debug configuration before running the debug process?
On the left window please choose 43xx-Wi-Fi_Debug_Window
1. run the debugger configuration.
2. switch to Startup page, add below instruction into the area below Halt option:
add-symbol-file build/eclipse_debug/last_built.elf 0x8000000
3. in the same Startup page, clear Run Commands area, default is like the phrase "stepi "
4. switch to Common page, click the "Launch in background "
then run the debug process, thanks.
Hi T-mat:
