Wi-Fi Combo
I was trying to run the WICED 4.1.0 debugger on a BCM943907AEVAL1F board to debug an OTA2 app. I kept getting a failure in launch sequence error. When I looked at the details of the error it was because the eclipse_debug/last_bootloader.elf file was missing. Most devices use the tools/makefiles/standard_platform_targets.mk file to copy the required files to the eclipse_debug folder. This device uses the following file instead:
WICED\platform\MCU\BCM4390x\BCM94390x_targets.mk
This file contains rules for two targets that interested me, copy_output_for_eclipse and copy_bootloader_output_for_eclipse. The first of these copies last_built.elf and the second was supposed to copy last_bootloader.elf into the eclipse_debug folder, but clearly was not. I added the second target to the dependency list of the first and I no longer get the failure in launch sequence errors when I run the debugger.
copy_output_for_eclipse: build_done $(BUILD_DIR)/eclipse_debug copy_bootloader_output_for_eclipse
    $(QUIET)$(CP) $(LINK_OUTPUT_FILE) $(BUILD_DIR)/eclipse_debug/last_built.elf
PriyaM_16
Thanks for the suggestion. It has already been taken care in the SDK.
PriyaM_16
