Hello All:
I'm having a problem where i'm sending the CYW43907 eval kit into hibernate mode for 4+ minutes, and it will consistently wake itself up after about a minute and a half. Whats even weirder is that if I send it to hibernate for only 1 or 2 minutes, it will stay in hibernate mode for the correct amount of time.
In terms of the code, i'm using the hibernate example snip from this post (43xxx_wifi Hibernate.c in WICED 6.2.1? ), with the only change made being the HIBERNATION_PERIOD_MS time.
Is there other considerations that going into choosing the hibernate time?
WICED Studio
Wireless MCU
hello :
there should have an overflow when doing multiplication :
you can modify it like this:
uint32_t seconds_to_wakeup = ms_to_wakeup/1000;
uint32_t ticks_to_wakeup = freq*seconds_to_wakeup ;
I have a test more than 5 minutes, it is correct.
hello :
