make.exe[1]: *** No rule to make target 'apps/ww101/02/02_blinkled/../../ARM_CM4/crt0_GCC.c', needed by 'build/ww101.02.02_blinkled-CYW94343WWCD1_EVB/Modules/apps/ww101/02/02_blinkled/../../ARM_CM4/crt0_GCC.o'. Stop.
make.exe[1]: *** Waiting for unfinished jobs....
Building Bootloader
Finished Building Bootloader
Makefile:351: recipe for target 'main_app' failed
make: *** [main_app] Error 2
MK file:
Name := apps_ww101_02_04_button
$(NAME)_SOURCES := 04_button.c
c file
#include "wiced.h"
void application_start()
wiced_init();
while(1)
button1_pressed = wiced_gpio_input_get(WICED_BUTTON1) ? WICED_FALSE : WICED_TRUE;
if(button1_pressed == WICED_TRUE)
wiced_gpio_output_high (WICED_LED1);
else
wiced_gpio_output_low (WICED_LED1);
File structure:
Which WICED Studio version are you using? Can you check in your system whether the ARM_CM4 directory exists in the following location 43xxx_Wi-Fi/WICED/platform/ARM_CM4?
I ran the example from CypressAcademy_WW101_Files/04_button.mk at master · cypresssemiconductorco/CypressAcademy_WW101_File... and was able to compile successfully.
Hello RaktimR-
Thank you for the response.
The following is answers
Downloaded
WICED Studio Wi-Fi/Combo v6.x SDKs
* WICED Studio 6.2.1
WICED-Studio 6.2.1 Installer (Windows)
ARM_CM4 in this directory
C:\Users\Al\Documents\WICED-
Studio-6.2\temp\43xxx_Wi-Fi\WICED\platform\ARM_CM4
CMSIS
3/21/2019 10:49:42 PM
crt0_GCC.c
8 KB 3/21/2019 10:49:42 PM
crt0_IAR.c
4 KB 3/21/2019 10:49:42 PM
hardfault_handler.c
16 KB 3/21/2019 10:49:42 PM
host_cm7.c
3 KB 3/21/2019 10:49:42 PM
platform_assert.h
5 KB 3/21/2019 10:49:42 PM
platform_checkpoint.h
platform_isr.h
7 KB 3/21/2019 10:49:42 PM
--AAO
Are you still seeing the error?
Still see errors
If I copy a snip file from the make Target as follows using the platform CYW94343WWCD1
snip.scan-CYW94343WWCD1_EVB download all builds OK. blinkled worked. Button has issues as below.
Complete files and output is as follows for button exercise in the tutorial. Same happens with blinkled exerise:
ww101.02.04_button-CYW94343WWCD1_EVB download
04_button.mk
NAME := apps_ww101_02_04_button
04_button.c -
#include "wiced.h"
void application_start( )
wiced_init( );
while(1)
else
ERROR
20:35:09 **** Build of configuration Default for project 43xxx_Wi-Fi ****
"C:\\Users\\Al\\Documents\\WICED-Studio-6.2\\43xxx_Wi-Fi\\make.exe" ww101.02.04_button-CYW94343WWCD1_EVB download
MAKEFILE MAKECMDGOALS=ww101.02.04_button-CYW94343WWCD1_EVB download OTA2_SUPPORT is disabled
Building Bootloader
Building Serial Flash Loader App
MAKEFILE MAKECMDGOALS=waf.sflash_write-NoOS-CYW94343WWCD1_EVB-SDIO OTA2_SUPPORT is disabled
- waf.sflash_write-NoOS-CYW94343WWCD1_EVB-SDIO
| Static |
Module | RAM |
App | 21130 |
Host MCU-family library | 11604 |
Interrupt Vectors | 388 |
libc | 556 |
platform | 1104 |
Ring_Buffer | 40 |
SPI_Flash_Library_CYW94343WWCD1_EV| 936 |
Startup Stack & Link Script fill | 486 |
WWD | 188 |
TOTAL (bytes) | 36432 |
Build complete
Finished Building Serial Flash Loader App
Compiling apps_ww101_02_04_button
apps/ww101/02/04_button/04_button.c: In function 'application_start':
apps/ww101/02/04_button/04_button.c:9:13: error: 'button1_pressed' undeclared (first use in this function)
apps/ww101/02/04_button/04_button.c:9:13: note: each undeclared identifier is reported only once for each function it appears in
tools/makefiles/wiced_elf.mk:232: recipe for target 'build/ww101.02.04_button-CYW94343WWCD1_EVB/Modules/apps/ww101/02/04_button/04_button.o' failed
- make.exe[1]: *** [build/ww101.02.04_button-CYW94343WWCD1_EVB/Modules/apps/ww101/02/04_button/04_button.o] Error 1
- make.exe[1]: *** Waiting for unfinished jobs....
20:35:50 Build Finished (took 41s.215ms)
Was able to work through. Thank you for help. Can close "Case"
