Wi-Fi Combo
Trying to setup BCM94343WWCD1 as a headset using a dsp for audio.
The schematic for BCM94343WWCD1 shows that it has a 4 line BT_PCM interface.
Is there any reference on how this can be hooked up to a dsp and how to route this pcm data to/from the headset profile ?
Sajid
vibac_2771176
New Contributor II
I have tried  with PCM audio routing for HandFreeProfile in BT module. You can use my code as a reference..please see the following link
Bluetooth A2DP and HFP Streaming
Vimal Babu
MichaelF_56
Thanks for the help vimal.babu_2771176
